Frank
After plating with Flash copper, sand lightly with 600 grit, wash with HOT water and Dawn or Polmolive, SP degreaser, then put it in pickle#4 just to make sure the copper is activated, then back in the Flash copper. Make sure you pass the water break test first. Hope this helps.
