Ok, put the part in the oven and set the temperature to Broil which is its highest setting. Checked the parts temp after about 5-10 minutes with the part still in the oven it read 450 degrees F. I pulled the piece out of the oven and immediatly checked the temperature again and it was like 200 degrees. This makes no sense I don't believe the temperature could of dropped over 200 degrees in that small amount of time...kind of confusing any help is welcome.
