At the shop i got a nice oven at home i got the poorman setup ... i use a toaster oven .. i use it for small stuff like blademan .. bolt's water neck's ect... depending on the temp on the outside it work's ok but not the best .. ised a heat gut to flow out powder the other day ... it worked just as good as a toaster ... i think i will be driving around on trash day and yanking a oven out of the trash ...
