Re: Getting Started...
That sander/polisher that you have may work with the mandrel on this site, but remember that faster is better. I think 4 amp should be plenty strong to swing that 8\" wheel. You don\'t want to put as much pressure on the tool as to slow it down. Let the compound do the work. I would suggest a sisal wheel with black compound and a sewn cotton with brown. That is as far as I go because I just seem to make it worse when I try all the other final touches listed on this forum. I guess I need more practice. anyway, Good Luck. I\'m sure CASWELL will give you the links to each and every one of the aforementioned items.
