From doing a little research, I am starting to get the feeling that I had a problem with the zincate and contamination. In the book it talks about plating out onto a dummy corrugated cathode. What is that? I am going to test the PH in the morning, and I am assuming I use the same stuff you would use in your pool to adust it.
thanks for all the help in advance.
Kenny
