The tolerances will be different depending on what type of gun it is. You'll likely start to see the gun lose efficiency after a couple of anodizes, then if you continue, you'll start to have leaks because O-Rings aren't as compressed as they used to be.
1-2 anodizes would be the max I would do on a paintball gun. Be careful when stripping not to leave the parts in too long; the stripper does attack the base metal.
