Old 06-21-2004, 05:05 PM
bzer1 bzer1 is offline
As a mechanic among other things...I do not recommend baking them with the seals in the caliper. The seals are neoprene, and will break down in sustained heat. Another thing to consider is the amount of contamination you will get with the break fluid still in there after cleaning. Rebuild kits are cheap to buy and easy to install. In my opinion, not worth the risk.
What are the calipers off of?
