Old 06-21-2004, 05:09 PM
upncoming's Avatar
upncoming upncoming is offline
upncoming is an unknown quantity at this point
Send a message via AIM to upncoming Send a message via Yahoo to upncoming
91 rx7
a guy emailed me with this info on doing it.
"squeeze all the brake fluid out, sandblast em, tape alum foil around the rubber boots/piston area, and you should be fine... just be sure you leave the threaded hole that the brake line threads into vented while its in the oven, you can plug it for powdercoating, but remove it when its on the oven."
