Old 07-02-2004, 09:32 PM
XK120DHC XK120DHC is offline
XK120DHC
Default Black Zinc Coatings
I am wanting to "plate" all the nuts, bolts, washers, etc. off my '53 Jaguar XK120 DHC in Black Zinc. I have talked to the local platers about this process, they use a large tumbling drum, which I'm not real keen on as small items can fall out of the gaps in the drum.. Not a problem on a Ford, but a big problem on a fifty year old Jaguar as the parts are made from "Unobtainium"!
The plater and I talked about wiring the small pieces together, this should eliminate the loss factor.. but I'm still nervous.
Having done business with Caswell Inc. in the past, I checked my "Complete Plating Manual" (Ver 2) for Zinc Plating and Black Chromate. Then I checked the website and found that the Zinc Crystals aren't available.. My option is "Copy Cad" and a Blackening dip..
Given that I have about a hundred pounds of nuts, bolts, washers and some small parts that I want in Black Zinc, and I printed out the Excel File "Surface Area Chart for Hex Head Bolts", I was floored to find that four 5/16" x 1 3/4" bolts equal 11.37".. The Copy Cad Plating Kit can only plate 12 sq inches at a time.
Now the Question:
What size tank/bucket/pond would be needed to do a "serious" amount of pieces (I'm not wanting to make a career of plating these nuts and bolts!)?
How many Anodes?
At how much voltage/amperage?
I'm not wanting to "experiment" with these valuable Jaguar parts.
Cost is a factor.. The local plating shop does up to fifty pounds for $40.
Convenience is a factor, as I must sandblast ALL the nuts, bolts and small parts in a short time before delivering they to the plater.. I could do "batches" at my own pace.
Additionally, I would like to hear from those who have serious experience using the Copy Cad and Blackener in plating a significant quantity (excess of fifty pounds) of nuts and bolts to learn about the ease of plating, quality of the plating, and exactly how much a "kit" would cover.
Chas
