  #23 (permalink)
Old 07-09-2004, 09:45 PM
Borgen,
We will be able to provide the unit set up for 220 VAC European use.
Skiddz,
Don't forget about the weld blemish. If you're pulling a dent out its probably in a place where it will show. Interesting idea, it might work.
If by powder coat application you mean to weld a wire to the work for the electrical connection, yes it will work. Use iron or mild steel wire (bailing wire) on steel. Since you only need to maintain a charge on the work to attract the paint particles (very low current) you can use very small wire, which makes the weld blemish even smaller.
