Go Back   Caswell Inc. Metal Finishing Forums > Anodizing Questions
Connect with Facebook
Old 07-03-2009, 12:22 AM
BobFrapples is on a distinguished road
Default Little Giant HC Agitation
Hey guys, I ordered myself a Little Giant HC pump for my tank agitation. I was wondering if theres any certain measurements I need to take before setting it up? I was reading around and people were talking about filters, but I don't know what for.
Is there a type of filter I need? Or do I just hook it straight up and allow it to pump the acid bath?
Thanks
Old 07-04-2009, 06:56 PM
Default Re: Little Giant HC Agitation
Anyone? ha
Old 07-06-2009, 12:56 AM
Brintiff is on a distinguished road
Put it in the bath and let it agitate, you don't NEED the filters, may not be a bad idea but I haven't had a problem with out one. Eventually I'll filter the bath.
Old 07-06-2009, 02:04 AM
sswee's Avatar
Moderator
If possible, check pump connections and plumbing with water before using in electrolyte. It's easier to make changes in the setup if needed, much safer and cheaper than replacing spilled electrolyte.
SS
Old 07-28-2009, 06:00 AM
Cartierusm is an unknown quantity at this point
I've got a question. I've just realized that agitation is really important just from reading these posts. I've never anodized but I've got everything setup and I'm going to start tomorrow or the next day. I already have a dual air pump for aquariums bubbling the solution, but noticed this thread.
I've got one of these
Taam Rio Plus 1700 Pump(UL)
It's a Rio Plus 1700 Submersible Pump it says it has ceramic bearings and Shaft. If this is true and doesn't have any metal parts exposed could this be used in the bottom of the tank to recirculate the solution? Or should I have it on the bottom of the tank and run a hose off of it to flow back into the top of the tank? Or will a dual air pump work fine for a 3 gallon tank?
Thanks.
Old 07-28-2009, 11:45 AM
Not too sure. The bearings on it might wear, but it doesn't say what their made of. It could work for a period of time but then it might die.
Old 07-28-2009, 04:09 PM
They say the bearings are cermaic. I think for a 3 gallon tank that the air pump would be fine?
  #8 (permalink)
Old 08-07-2009, 11:51 AM
Dan17581 is on a distinguished road
ide just put a pvc pipe with small holes drilled in it
that way you can have your whole tank agitaded and its safer both ways
  #9 (permalink)
Old 08-08-2009, 02:21 PM
acidrain's Avatar
acidrain has a spectacular aura aboutacidrain has a spectacular aura about
Any of the non-HC submersible pumps will work. I used them for a long time before going with a larger external pump.
I suggest you keep a spare at all times though... the plastic impeller will become brittle and break of the ceramic shaft right when you need it.
I do things.
Uniform air agitation Shepard Anodizing Questions 4 03-11-2009 07:46 AM
Little Giant Pump stevepelle91 Anodizing Questions 4 09-14-2008 08:43 PM
agitation fourkbmx Anodizing Questions 1 10-27-2007 03:08 PM
Agitation hurricaneracing Anodizing Questions 3 11-15-2006 11:40 PM
Agitation ??? hurricaneracing Anodizing Questions 1 08-30-2006 04:53 AM
