Wherever you locate your setup, you will have to control the fumes coming off the acid tank. Most people put that tank in a plywood box with a fan blowing air into it and an exhaust vent to outside the building. It could be done with a large hood directly above the surface sucking the fumes off, but this requires you to move a much larger volume of air.
Assuming this building is not heated or air conditioned, a much bigger problem will be controlling the temps in the various tanks. I don't know your location, but I know my garage gets below freezing in the winter and over 100 deg in summer. The acid must be maintained at 70 deg F +/- a couple degrees.
LinkBack URL
About LinkBacks
