+ Reply to Thread
Page 1 of 2
1 2 LastLast
Results 1 to 10 of 14
Thread: Heaters for what Tanks?
  1. #1
    Join Date
    Jun 2009
    Location
    Canada
    Posts
    262
    Default Heaters for what Tanks?
    Okay So I was talking to my friend who also does anodizing, and we realized we have different heating for the tanks. Some contaminate the chemicals though so we're actually confused on this now. So what types of heaters do you guys use for what tanks? Stainless steel and ceramic are my two and I use the following:
    Degreaser -> Stainless
    Deox -> Stainless (He uses ceramic because stainless contaminates?)
    Stripper -> Stainless
    Ano -> none
    Dye -> Stainless
    Sealer -> Ceramic (He uses Stainless, but doesn't stainless contaminate sealer?)
    So if you guys want to throw an input on what you use for what tank, I'd greatly appreciate it, hate to learn I'm contaminating my tanks.
    Share with Facebook
  2. #2
    Default Re: Heaters for what Tanks?
    I use nothing but ceramic. guess that the ceramic worked from the begining so never thought to switch. All the kits come with ceramic anyways.
    Share with Facebook
  3. #3
    Join Date
    Jun 2009
    Location
    Canada
    Posts
    262
    Yea but ceramic heats too slow for me on my bigger tanks. So I only use them for tanks that can get contamination.
    Anyone else?
    Share with Facebook
  4. #4
    Join Date
    Nov 2007
    Location
    Rochester NY
    Posts
    524
    You're fine using ss sheathed heaters in alkaline solutions. I'd have to check the ph of the de-ox, but I'm assuming it acidic, you'd want to use titanium or ceramic there.
    Here's a chart -
    Immersion Heater Solution Guide
    Quote Originally Posted by BobFrapples View Post
    Anyone else?
    James Bateman
    Share with Facebook
  5. #5
    Join Date
    Jun 2009
    Location
    Canada
    Posts
    262
    Oh wow that chart is great. So I can use SS for everything except the Deox?
    I thought SS contaminates the Nickel Acetate sealer?
    Share with Facebook
  6. #6
    Join Date
    Nov 2007
    Location
    Rochester NY
    Posts
    524
    Far from a chemical guy here, but I know that acetate's are made from acetic acid, and the chart shows quartz or teflon, so you'd want to use ceramic there.
    James Bateman
    Share with Facebook
  7. #7
    Join Date
    Jul 2009
    Posts
    116
    Yeah but the nickel acetate shows stainless on the chart, so what's the truth?
    Share with Facebook
  8. #8
    Join Date
    Nov 2007
    Location
    Rochester NY
    Posts
    524
    2 for 1 special, this one was harder to find.
    Compatibility
    If you're not sure of the SS alloy, go ceramic. Ceramics are mainly inert to attack by chemical, though I'm sure with the glass content Hydrofluoric acid would attack it some, which is definitely not in your sealer.
    Quote Originally Posted by Cartierusm View Post
    James Bateman
    Share with Facebook
  9. #9
    Join Date
    Jun 2009
    Location
    Canada
    Posts
    262
    I think I'll just stick with my ceramic for Sealer and Deox (now learned for deox!)
    Thanks Guys
    Share with Facebook
  10. #10
    Join Date
    Jul 2009
    Posts
    116
    Interesting, the bad part is the Stainless Alloy used on water heater elements, which is what I use, is Incoloy, and that's not compatible according to this chart.
    I've asked this before in this forum and I don't think I got an answer, so if anyone would let us know, how can you tell if the Sealer is contaminated?
    Plus I only put my water heater element in to get it to boiling and then take it out, so it's only in 25 minutes.
    Share with Facebook
+ Reply to Thread
Page 1 of 2
1 2 LastLast
Thread Information
Users Browsing this Thread
  1. Heaters
    By Empire03 in forum Anodizing Questions
    Last Post: 02-16-2009, 01:29 PM
  2. heaters
    By krymis in forum Anodizing Questions
    Last Post: 05-30-2006, 01:12 AM
  3. Clepco heaters
    By cbrooks in forum Electroplating Questions
    Last Post: 02-20-2006, 12:42 PM
  4. tank heaters
    By clydes in forum Electroplating Questions
    Last Post: 01-19-2005, 07:50 PM
  5. heaters
    By bikerrandy in forum Electroplating Questions
    Last Post: 12-12-2003, 11:20 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
