Originally Posted by
dmiom
and ...... have just noticed that you didn't explicitly mention the other process chemicals, their tanks or heaters.
If the parts are pre-made, you'll need, at a minimum, some form of degreaser, which is usually run hot. You must de-grease until the parts pass the water-break test.
After your strip/etch with purpose stripper or just lye, you may well need to dip it in de-ox/de-smut (cold) - some Aluminium alloys, after the strip/etch, can leave the non-aluminium alloy components on the surface (referred to as smut - and in fact the degree of smut can be a diagnostic pointer to the alloy). That smut needs to be removed before anodising.
After anodising and dying, you need to seal the anodising. The ano process forms a matrix of hexagonal tubes like honeycomb sticking up from the surface - that has a very slight tint to it but is basically colourless at the levels we use in the LCD method. When you dye, the dye goes down in the matrix (dye usually run heated but not too hot). Then if you just put the item into service, the dye will leach out from the matrix. The answer is to seal the tops of those cells to trap the dye in. Can be done in steam; but usual method we use is the boiling Nickel Acetate solution from Caswell. There is a lower-temperature seal but is not as hardy.
Dave
