+ Reply to Thread
Results 1 to 2 of 2
Thread: Two same alloy pieces..different results
  1. #1
    Join Date
    May 2009
    Posts
    120
    Default Two same alloy pieces..different results
    Thanks to recent improvements, most things are running better in my anodizing setup. But this weird problem keeps occurring.
    Two of the same pieces that need deox/desmut connected together here. Both were anodized (badly, see my dozen other recent threads), stripped in lye, rinsed, deox/desmut, then reanodized. One comes out fine, or fine-ish. The other is pitted and when it dries, the pits become white bumps.
    Two pieces of the same alloy, under same treatment and anoed in the same run, anodized at different colors, one dark grey, the other less so. Both pitted unacceptably and took dye differently, neither very well.
    One was anodized more often than the other, this was one piece's third run. But both were prepped the same way. I guess matching pieces must always be prepped, processed (and reprocessed) in lockstep, or both thrown out.
    Thoughts?
    Attached Thumbnails Attached Thumbnails Click image for larger version
ID:	1733   Click image for larger version
  2. #2
    Join Date
    Sep 2004
    Posts
    1,286
    Default Re: Two same alloy pieces..different results
    The previous problems on one and not the other become magnified in the next ano run.
    You could strip and sand out the pits, and then they might be OK.
    I wouldn't connect them that way... run individual wires to each of the parts, and then connected to a common bus bar (cross bar).
    I do things.
+ Reply to Thread
Thread Information
Users Browsing this Thread
  1. Hard ao on 2XXX alloy - Results
    By hotponyshoes in forum Anodizing Questions
    Last Post: 12-12-2008, 03:32 AM
  2. I need plastic pieces chromed
    By UnorthodoxCreations in forum Copy Chrome Kit Customers Only
    Last Post: 10-26-2007, 09:24 PM
  3. What's The Best Way To Repair Plastic Pieces ??
    By mivkas in forum Electroplating Questions
    Last Post: 10-10-2007, 01:35 PM
  4. Anodizing Multiple Pieces
    By DeanP in forum Anodizing Questions
    Last Post: 03-30-2007, 02:51 PM
  5. plating long pieces
    By rjh1936 in forum Electroplating Questions
    Last Post: 02-20-2002, 01:04 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
