Hey folks. I've been doing lots of searches on here the last few days and have picked up some good info, but it has all been tangential so far.
We made a big bad motor controller that is housed in a CNC milled aluminum enclosure/heatink. The prototypes we milled out of solid billets of 6061-T6 but for production we wanted to have the rough shape cast out of 356 alloy to cut down both on waste and milling time (otherwise we are chucking out 80# of aluminum to make a 12# part).
So far, so good, until we take the parts to get anodized. They leave the shop all gleaming and with the surface roughness you'd expect from a final finishing pass, but are are coming back significantly rougher (120 grit?) and with loads of tiny white spots unless we stick with clear.
My understanding is that the increase in roughness is from using a caustic (alkaline) etch which dissolves aluminum but not silicon, but as for the spots we aren't sure if the problem is that the raised bits of silicon are the problem, or pin hole porosity or what.
From what I have gathered - mainly from searching the forums here - it appears a slightly different anodizing process needs to be used for 356 aluminum. The process I have come up with (and would greatly appreciate help filling in the particulars) is:
1. degrease/clean
<Spray rinse>
2. mild acid etch (instead of the typical lye solution)
<Spray rinse>
3. deox/desmut (with a fluoride salt/strong acid - nitric?)
<Spray rinse>
4. Normal sulfuric acid anodizing (4.5-6ASF)
<Spray rinse/quick dip in baking soda solution/spray rinse>
5. Dye
6. Seal (preferably a low temperature sealer - nickel acetate?)
One anodizing shop said I needed to have the castings "impregnated" which, frankly, sounds like a real nightmare. Another said that bead blasting the exterior would take care of our problems.
Also, I have used the typical lye etching bath to strip anodizing, but that clearly is a no-no with castings. Suggestions on that would be appreciated, too, because a machined enclosure has a lot of "added value" in it at that point and it really sucks to have to chuck into the recycling bin because the anodizing didn't go well.
Thanks!
LinkBack URL
About LinkBacks
