After reading countless posts and the LCD Ano manual, I decided to do my first run but lost the connection after 15-20 min. I had tapped a M3 hole in my part and threaded my aluminum anode into it, but the connection was to loose and the wire must have anodized.
After 20 minutes in the ano bath at 1.5A (6 ASF given that my piece is 1/4 Sq. Foot), I lost connection when I air agitated the part. I knew something was amiss from the get-go when I the initial voltage read on my CC PS was in the vicinity of 15-17 Volts. I immediatlely suspected a poor connection, and after air agitating, I could not muster any amperage at all.
My question is: how to go from here? Do I need to strip whatever layer that has seemingly anodized in that 20-minute span (have not idea of the thickness) using the Caswell stripper product or can I just re-start the ano process with a better connection as if nothing had happened?
Note that my connection this time will be improved by adding an aluminum nut fastened to the wire and a better tapping job. I am planning on switching to titanium wire in the future so the anode does not anodize, but for now I am restricted to using alu.
Thanks in advance.
Patrick
LinkBack URL
About LinkBacks
