Go Back   Caswell Inc. Metal Finishing Forums > Anodizing Questions
Connect with Facebook
Old 10-28-2009, 12:28 AM
pat327 is on a distinguished road
Default Tips on Cleaning Oil from Anodized Parts
Hello,
I had the outer fork tubes from my motocross bike anodized gold recently. They are an older type, so they are composed of two separate aluminum pieces (the main tube and a ring that holds the oil seal in place).
Anyway, it appears that oil is somehow seeping up through these rings and staining the main tubes. I used a little bit of transmission oil to lubricate the seals and make them easier to install, so I think that whatever is left of that continues to find its way up my forks.
I clean them regularly and I'm able to remove the oil from the main tubes every time. However, when I check them the next day, the oil has seeped back up. So, no matter what I do, I cannot keep these forks clean.
I've tried to break the oil down by spraying hot water and simple green into the gap between the main tube and the ring, but that hasn't gotten me anywhere. I've scrubbed with a toothbrush and soap, but that hasn't done the trick either.
Can anyone recommend something to clean them with that will break down the source of this oil, but won't damage the anodizing?
Here's a picture. That discoloration you see near the ring is the oil (or whatever it is). It looks more dramatic in person. I really doubt that the fork seals are broken as there is nothing seeping down onto the hard-chromed lower forks. It's a really odd situation and very frustrating to a crazy perfectionist like myself.
I've noticed that this anodized coating is highly sensitive to stains. Even touching the forks will leave a stain that requires soap and water to remove. Is this normal?
Any help is very much appreciated.
Thanks,
Patrick
Old 10-28-2009, 03:45 AM
gcdrummer02 is on a distinguished road
Default Re: Tips on Cleaning Oil from Anodized Parts
do the parts feel sticky or tacky to the touch?
Old 10-28-2009, 12:11 PM
Countryboy1966 is on a distinguished road
Sorry for the hijack,
I have had parts annodized for me that felt stick or tacky to the touch. What does this mean?
Old 10-28-2009, 12:26 PM
No, they don't feel sticky at all. It doesn't even feel oily, it just looks that way.
Old 10-29-2009, 05:05 AM
if it feels sticky to the touch, it means it didn't seal properly, and its usually capillary action, grabbing onto your skin oils.
Take a little bit of 3 in 1, or WD40, and wipe down the forks. See if you still leave finger prints then, and if you do, they should just wipe away.
Old 10-30-2009, 11:32 PM
Thanks for your help. I sprayed some Maxima SC1 on them and it made them a really nice, glossy, uniform gold color.
Old 11-10-2009, 11:45 PM
maahi is on a distinguished road
Nice and useful tips.Thanks for sharing.
Brass Sheet
Nickel cleaning tips STAINER88 Electroplating Questions 1 07-10-2007 03:58 PM
Need a few parts anodized corporate666 Services Offered/Wanted 1 04-30-2007 12:19 PM
cleaning anodized aluminum rancidnsx Anodizing Questions 0 01-27-2005 12:56 AM
Need parts custom anodized? jagrc Services Offered/Wanted 0 01-05-2004 05:48 AM
Sealing anodized parts? desert_roamer Anodizing Questions 1 01-25-2002 08:41 AM
