been doing smaller parts with good results using 720 rule. Here my question on larger parts 632 square inches parts or 4.39 square foot my power supply is 30v @ 20amp max (Mastech) so with the 720 rule i am ano at 4.33 asf with the caculation i ano @ 4.33asf 19amps 10.83 max volts 124 minutes but on the power supply using CC my amp is at 19 amps but the volts read 14 vdc, 720 rule says 10.83 max if i adjust the volts the CC goes away Will these parts ano right with the volts at 14? I put parts in bath (25 gallon) to take initial reading before i start a run. Thanks Jason |
Volts vary time to time. Thats why it says volts may be off than what your occuring.
Several things affect volts, distance to cathode, acid:water ratio, temp of bath, etc. It should run fine. Watch the temp with that many pieces though, your bath may get quite warm over time. |
