Go Back   Caswell Inc. Metal Finishing Forums > Anodizing Questions
Connect with Facebook
Old 11-03-2009, 02:58 PM
91slicktop is on a distinguished road
Default Finally getting started
Bought the Caswell standard kit a while ago, but never had time to mess with it or ever get it set up. Forgive my ignorance with anodizing, but as i just stated, I'm new.
For now I plan on just using the buckets that came with the kit, until i get a little experience under my belt, and have the need to expand.
I need to get some things sent to me that were left back home when I moved. The 2 glass heaters and the Air pump. I also need to obtain the 1 gallon of Sulfuric Acid, then I should be good to go.
I have the Model HY3020E power supply as well.
I've been reading over the manual, but does anyone have any little hints, tips or tricks for me since i'm just getting started? I'll probably be posting back more once I start setting up to get more help on specifics since the pictures in the manual aren't the best in the world.
Hopefully in a few weeks time I'll be posting up proud pictures of my work! Until then, I'll be waiting to hear everyone's advice and tips/tricks!
Old 11-03-2009, 05:27 PM
Default Re: Finally getting started
Also what do you guys do for your distilled water? seems sort of expensive to go out and buy multiple gallons from the store..
Old 11-03-2009, 08:31 PM
BobFrapples is on a distinguished road
Not sure about tips and tricks, thats prety broad. Just follow the instructions, and then if you do run into a problem we're all here happy to help.
Distilled water, if you don't want to buy from the store, you can purchase a R.O. Water System. Their a couple hundred, but you save in the long run.
Distilled water isn't that expensive where I get it from, $1 a gallon. I occasionally go get 5 gallon jugs, so I don't notice it that match.
Old 11-03-2009, 11:10 PM
stayhi is on a distinguished road
anything thats purified w/ reverse osmosis. i got a 5gal jug and i refill it for $2.50 at a machine outside the liquor store right next to my house.
no tips or tricks for you as ive only been doing it a couple months, just read every post in this place and do some runs. the kinks will work themselves out over time.
but i would advise to put a diode in the Mastech, or i just connect the leads before turning on the power supply to avoid any kick back in current. These chinese machines die easily.
Old 11-04-2009, 02:57 AM
where do you hook the diode? On the positive side between the item and the machine?
Old 11-04-2009, 03:17 AM
i believe so. i never got around to getting one so i never looked back into it.
:Edit: search function- diode + mastech. Bob's thread has your answers Power Supply --> Ano Tank question
Old 11-04-2009, 07:02 PM
cool ordered my gallon of acid today, gonna look into getting the Diode. Once that stuff arrives I should be ready to start setting up. Maybe another week or so!
  #8 (permalink)
Old 11-05-2009, 03:27 PM
dmiom is on a distinguished road
Have a look at this recent thread on power supplies which included info on diodes
Dave
  #9 (permalink)
Old 11-06-2009, 12:23 AM
acidrain's Avatar
acidrain has a spectacular aura aboutacidrain has a spectacular aura about
I hope you're getting battery acid, and not lab grade acid.
I do things.
  #10 (permalink)
Old 11-11-2009, 10:37 AM
isn't battery acid sulfuric acid?
what is the difference?
Finally Done!!!!! Deecoat Oven Building Forum 7 12-11-2007 05:16 PM
Ive started finally atroxr7 Oven Building Forum 2 03-08-2007 07:59 PM
I finally got started.... red04cavy Powder Coating Questions 1 01-01-2007 07:58 PM
My Oven Is finally Done! kcenicola Oven Building Forum 4 12-22-2006 07:00 PM
finally ordering a kit shawnkloker Electroplating Questions 0 09-05-2006 08:37 AM
