![]() This is a piece of aluminum pipe 2.9" outer diameter 2.5" inner diameter 2.35" hight .2" wall thickness 2.9x3.14= 9.11" Outer Circumference 2.5x3.14= 7.85" Inner Circumference 9.11x2.35= 21.41" outer surface area 7.85x2.35= 18.45" inner surface area 2.9/2=1.45" outer radius 2.5/2=1.25" inner radius (A= pi r2) 3.14(1.45x1.45)= 6.6" surface area of outer circle (top/bottom) (A= pi r2) 3.14(1.25x1.25)= 4.9" surface area of inner circle (top/bottom) Subtract inner circle area from outer to get wall surface area x2 6.6-4.9= 1.7 x2= 3.4" top and bottom edge surface area 3.4 + 21.41 + 18.45 = 43.26 square inches? 43.26 x .0069 = .3 square feet? 720 rule calculator at 4.5 ASF @ 1mil = 1.35A for 120mins? Any easier way to do this? My brain hurts... What do you guys do for irregularly shaped objects? This was a simple piece and took some serious brain power even with a calculator! I'm sure it'll get easier the more I do it though. |
Ok, this is actually a pretty big piece in my eyes for the kinds of things I will be anodizing, so I think I'll order up just a 5A power supply. But, maybe 10A if the price is right so I can expand.
So, does the surface area have to be exact to the .01"? Or is it just a quick going over with calipers and a little guess-timating along with a calculator? I guess what I'm asking is do I have to be as thorough with my measurements as I was with this piece pipe? |
I would agree if doing a couple of parts. I normally do batches of the same part, if is skip smaller areas like the wall thickness of your part on all of them parts in the run, it can add up to a bite of surface area.
Yes, ddrink is right, if its a couple parts its fine. But if your doing lots of parts and ignoring the wall thickness, just calculate for one, and multiply by however many parts you have.
| Anodizing calculations (720 Rule) | GramSlam | Anodizing Questions | 39 | 09-18-2009 02:21 AM |
| Re: Anodizing calculations (720 Rule) | texsol | Anodizing Questions | 4 | 11-15-2005 06:29 PM |
| Correct applications? | Bariman | Electroplating Questions | 2 | 03-05-2005 03:28 PM |
| is this correct?please answer | engle_andrew | Anodizing Questions | 2 | 01-28-2005 11:31 PM |
| PSU calculations | kickn | Anodizing Questions | 19 | 09-07-2004 05:20 AM |
