+ Reply to Thread
Results 1 to 3 of 3
Thread: pump requirements
  1. #1
    Join Date
    Aug 2009
    Posts
    268
    Default pump requirements
    Okay, my 1/2HP chiller requires at least 750 GPH for smaller tanks (and smaller meaning 100 gallons)
    My tanks is around 35 gallons.
    I am set on the little giant HC brand
    but what about size
    It is either the 1/25HP or the 1/8HP (which is double the price)
    I am thinking I only need the 1/25 because of my tank size.
    Would I be correct? or am I going to regret buying the smaller size?
    Share with Facebook
  2. #2
    Join Date
    Nov 2004
    Location
    close to Austin, Texas
    Posts
    1,282
    Default Re: pump requirements
    The 3-MD-HC I run on a 60 gal. tank was also run on my 20 gal. tank. It is rated at 720GPH. It works fine on either tank.
    Things to remember with MD(magnet drive) pumps
    You need to run the size pipe that the pump is set up for on the inlet side.
    You may restrict the output of the pump but not the input side.
    You can restrict the output of the pump, this will decrease the volume output of the pump but increase the pressure going into the tank to increase agitation.
    Side note on pumps and chillers. Chillers are designed for a certain flow rate to chill properly. Too great of flow will decrease the chillers ability to chill. You can take a higher output pump and restrict it down to the needed flow rate.
    Tip on new set up. Leave the acid out of the tank at first. Use tap water. Set up the pump, chiller and plumb the tank. Check the flow with the tap water. You can also put a slight amount of ground black pepper in to check for dead spots in the flow. Hang some trial pieces in to see the effects of a parts load on the flow. Let run long enough to check for leaks or problems. You can also try different plumbing set ups before gluing any PVC. A few hours or days doing this will be worth the effort. After everything is to your liking, drain , rinse, and mix the electrolyte.
    SS
    Share with Facebook
  3. #3
    Join Date
    Aug 2009
    Posts
    268
    Quote Originally Posted by sswee View Post
    SS
    That is the one I bought Stupid UPS messed up on shipping and delayed me the weekend.
    Thanks though I should see monday how it works.
    Share with Facebook
+ Reply to Thread
Thread Information
Users Browsing this Thread
  1. How to Calculate load requirements for Stripping.
    By Ron_B in forum Electroplating Questions
    Last Post: 06-05-2009, 07:16 PM
  2. wattage requirements
    By chicagorich in forum Powder Coating Questions
    Last Post: 02-05-2005, 02:59 PM
  3. Power Supply Requirements
    By KomaToast in forum Electroplating Questions
    Last Post: 02-26-2004, 11:19 PM
  4. EPA REQUIREMENTS, PERMITS
    By harris11 in forum Electroplating Questions
    Last Post: 09-14-2003, 02:18 PM
  5. power requirements for Fast Gold
    By jomida in forum Electroplating Questions
    Last Post: 01-15-2003, 10:51 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
