Originally Posted by
woodjames
The ph won't always give a good reading, as alkaline cleaners get dragged in, and pretreatments that involve acids get dragged in...etc... Not to mention very low ph's are difficult to measure. Titration comes into play when the amount of aluminum in the bath changes the specific gravity. But in anodizing baths it's fairly constant, so truly the easiest/quickest way is to take a specific gravity reading. When you notice the s.g. is changing, your bath is getting contaminated with something. Sulfuric at different concentrations has published info as far as what the s.g. is at a given %. Don't bother with all the stuff for titrating yet, just keep taking s.g. readings, then when they change, go forward with titration.
You should be able to find a s.g. meter that will cover the range you need at a pool store or auto-store. You dunk it in, take a reading and move forward.
