Results 1 to 3 of 3
Thread: Pickling Ti Rod
  1. #1
    OWWM is offline New User
    Join Date
    Mar 2012
    Posts
    42
    Default Pickling Ti Rod
    Guys today I'm going to try and pickle my 1/16 Ti rod.I adjust the voltage up to 15 volts and was wondering how long to leave it and do I need to set the amps(no reading)?Some place I readed that to leave it on till the voltage drops to 0.I can't remember if that info came from here or that google guy.Tks and guys sorry for all the questions----Carroll
  2. #2
    Join Date
    Mar 2012
    Posts
    42
    Default Re: Pickling Ti Rod
    Well I'm guessing that the rod needs to be in the solution to burn the rod,cause I've tried it for about 30mins without success,still at 15volts and no amps in the dry bucket(no solution).---Carroll
  3. #3
    acidrain's Avatar
    acidrain is offline Metal Finishing Guru
    Join Date
    Sep 2004
    Posts
    1,754
    Run all your Ti hanging wires in solution at full volts, full current until voltage drops to near zero. The rods will turn color, which corresponds to the amount of volts you ran (20 volts will be a different color than 30 volts).
    I do things.
Thread Information
Users Browsing this Thread
  1. Pickling Titianium???
    By OWWM in forum Anodizing Questions
    Last Post: 05-26-2012, 08:50 AM
  2. Pickling?
    By neil in forum Electroplating Questions
    Last Post: 05-29-2003, 11:57 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
