I've always used a 4 port aquarium pump but I'd check out this thread >> http://www.caswellplating.com/bbs/viewtopic.php?t=1452 .
Still setting up the shop...........I need to figure out a way to aereate many tanks in the twenty gallon range. I don't think the small aquarium pumps will do it based on a couple of prototype set ups I have been experimenting with. The 1/2 inch CPVC I have been working with has 1/16 inch holes drilled every 2 inches around the perimeter of the frame which is 12"x24", with a "T" coupling, for air input, coming out in the middle of one of the 12" sides. I have tried three different old aquarium pumps that I had lying around with limited amounts of bubble discharge from the holes I drilled. If the lines aren't exactly level, some of the lines will fill up with water and wouln't even discharge any air, due to the limited air pressure.
I read an article pertaining to printed circuit board production that described a blower setup from the exhaust side of a small shop vac. Is this safe air to blow in to various chemicals and dyes? I doubt a shop vac would last very long..... Are there any good long lasting air systems that are reasonably priced out there for a tank line such as mine? I'm pretty handy at crafting things but I need to know what kinds of air sources can be used for this application.... I have a plan to tie the tank lines together with a common air source running through 1/2" CPVC line with a ball valve controlling airflow into each tank. Any ideas on how to supply with air?
Whistule, what kind of volume do these types of pumps produce? Can you do lots of tanks with one? How much? Where? Any links to find them on the web? Tell me more..I need to get set up before Christmas.
Thanks,
Aaron
Rather than aeration, perhaps you should look into agitation by re-circulating the electrolyte. Personally, I think it is easier to move the electrolyte around rather than trying to make sure you have complete coverage using bubbles.
Boyu has a number of water pumps for use in aquariums. I've been using the 1300B model which is sufficient for a 5 gallon bucket, but they have others and they seem to tolerate the electrolyte solution.
I posted a response in the thread mentioned in whistules reply above detailing how it was used. It should be easy to up-size it by using multiple pumps or larger output pumps.
Eastex,
I'd go with Neilfj's plan but here's the info anyway as I know my system does work.
I couldn't tell you what volume the pump produces but you do need to have one outlet per tank on the air pump (or alternatively you can swap over the air line). My pump has 4 outlets which is quite handy as you don't have to do too much switching over. I managed to pick one up through ebay from an aquarium/pet shop. It looks pretty similar to the ones on this site >> http://www.enkoi.com/pumps/boyu.html . I'd get something with a bit more power and a variable output if I was you.
The tube is snaked round the bottom of the tank and perforated with holes to give good coverage.
I suspect from what neil and fiber are saying that this is probably a slightly inferior but cheaper option ??
I don't know if any method is superior or inferior to any other method. All you want to do is move the solution around rather vigorously. What it comes down to is what is cheapest, easiest to setup, operate and maintain in your particular situation.
It sounds like in your situation it may be better/easier/cheaper to set up a mechanical method of agitating the solution. Without knowing the exact layout of your set up, you could go simple...for each tank, a small, variable speed motor to which a submerged paddle or propeller is attached. The paddle will provide the agitation, and by adjusting the speed of the motor, adjust the amount of agitation.
Complex would be a drive wheel attached to each tank. Each drive wheel would have a paddle attached. Then connecting all the drive wheels to a single motor/drive shaft.
neilfj
i was thinking of doing something like that. with a proppler type agitater. but the problem is that the motor would need a shaft extender and all parts in the sulution would need to be titanuim or aluminum. out of aluminum would be the cheapest. but making something shouldn't be to hard. also the motor should be sheilded from the solution.
I appreciate the input guys, but back to the original question. Whats the best air source for air agitation? I'm sure the aquarium impeller pump works fine, but I'm somewhat skeptical about running anything in my anodize tank thats not a recommended material (magnets and a steel shaft.) I need to set up agitation in some other tanks as well, so I was really looking at something that was more of a "ganged" air source. I'm trying to find a source that I can bridge together with 1/2" PVC and run on/off valves in to the tanks for air flow control in a given tank. Any ideas?
Thanks,
Aaron
The best solution would be to use a compressor with regulator to control the pressure and output. A shop-vac would probably work, but it would have to be filtered. Blowing dirt and dust into the solution can't be anything but bad, not to mention the noise.
Easttex: Yes, the shaft would have to be extended, but you could use a wood dowel for this, or aluminum rod, along with an adapter or clamp to connect from the shaft to the extension. You wouldn't need much shielding for the motor as you don't have to deal with the corrosive mist, but shielding to protect against accidental splashes would probably be a good idea.
I've heard that a compressor/regulator set up will introduce oil and other contaminates into the baths, although I considered this set up before learning of this potential problem. As you said a shopvac would have to be filtered on the intake side so as not to produce dust and other undesirable elements into the solution. Any ideas how much commercial air spargers are and what pressures they produce and at what flow rate? I hate to think that my only option is to go with a professional grade setup for a modest tank line. There has got to be something really clever that will work well and save me some bucks. I really appreciate the input![]()
Thanks,
Easttex
