Yes, it is possible to change dimensions by stripping. I've never dealt with hardcoated items, only Type II anodizes. With these, I've never changed tolerances enough to be measured by a 0.001" caliper. For my stuff, this has not been enough of a tolerance issue to worry about.
However, I can imagine that many things such as guns may have tighter tolerances, so this might become an issue. |
00_buckshot, remember me?
In this situation for once, things will tend to go in your favor, assuming it really is 2 mils thick: 1. It's not likely to occur and dangerous to attempt removing all of the anodize from the pinholes. 2. If you removed 1 mil from the surface after stripping, you increase the pin hole diameters 2 mils. You add .3 to .7 mils when you reanodize. this decreases the hole diameter .6 to 1.4 mils. Since this is type II anodize, about 2/3 of it is above the surface. The reduction in diameter is .4 to .9 mils. This results in the hole diameters being 1.6 to .4 mils oversize. The milspec tolerance for the holes in a M-16 lower is + 1.5 mils - 0. 3. Since because of 1. (above) you probably won't encounter this situation anyway. Another reason why you want to leave the existing anodize in the holes. It won't show anyway. 4. In practice, it's usually necessary to ream the holes after reanodizing, back to the original specs. |
I have found the safest way to strip a high dollar item is to alternate chemical stripping with beadblasting, you take off the anodize in layers. It's slow, but its safer. When beadblasting avoid holding the blasting gun right over the pin holes, just sweep across them, trying to blast the holes clean can enlarge them.
Masking the holes before chemical stripping would be a good idea, rubber cement seems popular as a masking material. Test it first to be sure that the stripper won't attack it. |
| stripping anodizing off aluminum | broker1234 | Metal Polishing Questions | 1 | 01-16-2005 10:28 PM |
| Color depth vs. anodizing time | NeoMoses | Anodizing Questions | 17 | 02-03-2004 10:06 PM |
| Anodizing temperature | mudwhump | Anodizing Questions | 8 | 12-16-2003 11:18 AM |
| Anodizing different alloys | TONYZ | Anodizing Questions | 2 | 11-02-2003 02:31 PM |
| anodizing stripping | neil | Anodizing Questions | 3 | 10-04-2003 11:36 AM |
