Go Back   Caswell Inc. Metal Finishing Forums > Anodizing Questions
Connect with Facebook
Closed Thread
Old 12-19-2003, 02:43 PM
wildman
Default FiberGeek.....I need help with your VCCS schematic
Hello FiberGeek,
I am building a VCCS from your schematics. I would like to ask a few questions, if I may.
I understand that the MOSFETS need to have their grounds isolated from the main circuit but should they also be isolated from each other?
Reason asking is that I have a long heatsink with a fan already mounted on it that would work nicely for the three TO-220's.
In the same line of thought, I purchased three .1 ohm 50 watt aluminum housed resistors that are connected to the "sink" leg of the TO-220's. Would there be any advantage to heatsinking these also? or could they be mounted directly to the circuit board? ( board is a "hobby" board from Radio Shack.)
Final question.....
On the schematic, the LM336BZ-2.5 ( labeled VR-1) does not have a connection on its 3rd leg. Does this get isolated from the circuit or is it to be connected to somewhere in the circuit?
Since I don't understand much about how the VCCS actually works, I do appreciate your help.
Thank you,
Dan
Old 12-19-2003, 04:57 PM
By MOSFET "ground" I think you mean the terminal marked "G" which is the gate, not ground. Connect the gates as shown; if the distance between the MOSFETs on your heatsink is less than 3 inches, no additional isolation is necessary.
R9, R11, and R13 (0.3 Ohm 10W) are connected in parallel to provide 0.1 Ohm 30W. You can use 1 of your 0.1 Ohm 50W resistors. Heatsinking your resistor is not required. The "S" means source, not sink. The "D" means drain.
Don't connect anything to pin 3 of VR1.
I should write a Theory of Operation for this circuit and email it to Jnbsystems so he can post it.
Old 12-19-2003, 08:19 PM
wildman
Thanks Fibergeek,
I appreciate the quick response.
Dan
Closed Thread
Fibergeek's VCCS Power Supply Diagrams Posted jnbsystems Anodizing Questions 10 02-09-2005 10:20 PM
Experienced Platers, Fibergeek has a Technical Question Fibergeek Electroplating Questions 3 11-04-2004 12:50 AM
Acid copper plating problem! Attention Fibergeek Gabourie Electroplating Questions 10 08-15-2004 12:24 AM
For Fibergeek NeoMoses Anodizing Questions 0 01-27-2004 11:59 PM
VCCS questions NeoMoses Anodizing Questions 11 10-09-2003 05:15 PM
