Old 12-20-2003, 06:11 PM
rwizinsky
Default Surface area measurements
I've just recently setup my system. I setup a large battery charger 2/35/200 with the dimmer switch as recommended by the LCD system. I've tried a couple parts and am fairly happy with the results. The 1st piece came out alright but abit light, it was a gold part. The 2nd parts I did I strung a bunch of small ones together but ran it for a longer time. My problem is that it seems quite impossible to calculate the surface area of these complicated contoured machine parts with lightning holes and everything. I just ran the 2nd batch about 1/4 power for 5 min then 1/2 power for 5 min, then full up for 1/2 hour. I see all the posts about inconsistant results but so far everythings worked out alright am I missing something? There is one of the parts in the scrolling marque on my web site, here:
www.professorwiz.com
I did notice one thing (thank goodness for the LCD usage of the dimmer). I ramped the power up all the way when I first started the 2nd set because I wanted to see what the difference was. The titanium wire stated glowing red so I backed it off all the way and went a bunch slower and that seemed to work alright.
One other thing that sealer seems quite noxious, it's way more stinky than the acid, anybody else have this problem?
Russ
Calculating Surface Area, the Easy Way. PrecisionPB Anodizing Questions 6 05-28-2005 03:56 PM
Anodizing without knowing surface area? sbpoole Anodizing Questions 3 01-06-2005 08:09 PM
Surface Area pre/post Bead Blasting kickn Anodizing Questions 2 10-26-2004 06:11 PM
surface area for electroless plating tepece Electroplating Questions 1 02-09-2003 08:54 PM
Surface Area vs. Current shorton Electroplating Questions 3 11-06-2002 12:36 PM
