i've been working on this for a few weeks now. all thats left is building a stand. snd getting a another 12 volt power supply.
i'm using a 12v dc 8rmp with a pulse timer relay to slow it down. heres a seek peek of the drive and shaft.
these scarps weren't the best. plus i didn't do a good job clean or polishing them let alone my sealers ph was way off. so these pictures aren't for nothing more then to see if a fader can be done. and worth while.
the smaller part in the pictures was the first atempt. the fade failed cause the pull out speed was to slow. the peice is ruffly 7" long and the color starts 1" from the end. it took 26 minutes to get the part out of the dye. way to slow. lol ![]() the longer peice was the second atempt. the fade starts in the midle of the piece. i started this with the motor backing it allittl faster and after about an 1" or to out i slowed the motor down again. but not slow enough. took ruffly 15 to 20 minutes on this one. takes a little getting used to but i think it's well worth the time it will take to figure it out to suit my needs. ![]() takes a little getting used to but i think it's well worth the time it will take to figure it out to suit my needs. so basicaly if you do a faster speed out at first to get the beging of the fade then slowly decrease the speed of the motor to get a deep color on the end. any question feel free to ask. this entire setup was build by me in my free time. as a hobby michinest i think this was alot of fun to design and build |
Wonderful stuff!
Thanks for all the hard work you've shared with us. Perhaps you could make some notes on times, and lengths of fades, so we could produce some sort of chart?
im sorry, but is sitting there for like 10 minutes dipping the part in and out of the dye that hard to do, its what ive been doing. its how i got these results
http://www.sexyturtle.com/P7210031.jpg http://www.sexyturtle.com/P9010014.jpg just my advice, that whole complicated contraption might be a little hard for people to make. hey since i figured this one out without having to fabricate a motorized fader, and waste oodles of time, can i get the reward? |
i've do it that way. but with certin colors it's hard to try and get the efect you realy want. this actauly makes it easier to get a longer fade with a deeper color change and no drastic lines. in short it gives you more control. plus i didn't exactly design it so you can just grab a bunch of parts and slap it together. so i don't expect anyone to just build one.
it's just any eisier sulotion and using some of the pro setup design to make this. if i could find someone to make me a inexpncive cnc type contorler this would make it even more easier. |
