Old 01-12-2004, 02:44 PM
mudwhump
Default Stainless hardware
Is it OK to use stainless steel hardware to fasten the wire to the anode? I've read that you should only introduce aluminum, titanium, or lead to the acid bath, but titanium or aluminum screws are harder to find. Thanks
Old 01-12-2004, 05:20 PM
NeoMoses
I found some aluminum screws at www.mcmaster.com I'm not sure if SS should be used to attach the electrode or not, although I have heard that it's OK to be in the anodizing tank.
Old 01-12-2004, 07:33 PM
All common stainless steel alloys are rated "C" (marginal) to "D" (poor) for corrosion resistance to sulfuric acid, even as dilute as we use. How much trouble will it cause? I don't know; but like most things in anodizing, it's probably a matter of degree. Use aluminum hardware like Neomoses, or titanium hardware if you can afford it.
Old 01-12-2004, 07:51 PM
rwizinsky
Default titanium bolts
Servi Sure has some great deals on Titanium nuts and bolts, I thought they were about $1.40 per bolt and $1.00 or so for nuts. For something that'll be used a bunch it really isn't too bad. It's not like I needed 100, but perhaps in your application you do. I went that route
Old 01-12-2004, 09:27 PM
Rwizinsky, could you post a link to Servi Sure? The price you mention looks attractive.
Old 01-12-2004, 10:05 PM
rwizinsky
Default No problem
Here it is, I believe I got it off the caswell web site.
http://www.servisure.com
Good Luck.
Russ
www.professorwiz.com
Chrome on stainless steel Fick Other Metal Finishing Questions 3 07-05-2005 12:27 PM
blackening 303 stainless?? toku58 Other Metal Finishing Questions 0 01-27-2005 02:45 PM
I need a durable dark finish for stainless. FitzLaughlyn Other Metal Finishing Questions 2 07-17-2003 01:41 PM
Stainless Steel Help, Please rbkemp25 Metal Polishing Questions 4 06-21-2003 06:59 AM
Silver over stainless Rusty Armstrong Electroplating Questions 1 03-25-2002 08:11 PM
