Old 01-26-2004, 05:18 AM
Sid03
Default leaving cathodes in ano tank?
So, you guys leave the cathodes in the tank or not? Ive noticed that after I clean them and then stick them in the tank to use next time, I white layer will burn off the cathodes and collect at the bottom of my tank. I normally just dip them in the neutralizer, rinse, and let sit until next time I ano. Im wondering if it would be ok to just let them in the ano tank?
Old 01-26-2004, 03:10 PM
NeoMoses
I pull my aluminum cathodes, but leave lead cathodes in the tank. Aluminum tends to corrode, turning black, much quicker than lead. I've left lead cathodes in the tank for over 8 months without any noticeable corrosion.
using aluminum as a cathode scocklin Anodizing Questions 19 03-31-2007 01:18 AM
Need opinions on my next tank. jtsuttle Anodizing Questions 4 03-29-2004 01:32 PM
Other materials in Anodizing tank? usao Anodizing Questions 4 03-04-2004 10:07 PM
Tank Heating Questions. meganine Anodizing Questions 1 08-03-2003 04:20 PM
Heaters for a 45 gallon tank jsnow2060 Electroplating Questions 2 01-26-2003 08:47 AM
