I have an aluminum part that has a broken steel pin positioned about 1/16" of an inch below the surface of the part I want to anodize. It has proven impossible to drill out with my equipment. Can I just plug this hole with Caswell's masking agent or does the steel have to be completely removed? Keep in mind we are only talking about 1/4" max in total area of the broken steel pin. Is this that much to worry about?
If I was to attempt to anodize it with the pin exposed what could/would happen? Thanks for the help. |
I believe that anodizing it with the steel exposed will dissolve the steel into your acid bath. I've heard (although I've never done it myself) that this is a method sometimes used to remove otherwise impossible to remove broken bolts. I'm not sure if the amount of steel dissolved would affect your anodizing results or not, though.
I believe masking it would work if you want to keep it from reacting with your acid during andozing. |
what i have done in the past is i have a speprete anotank setup. and use the to desolve taps that have broken in parts i have made. only draw back is you would need to strip and polish it after this is done. but it will only need to stay in the stripper more then a minute or 2 since it's not sealed anno. this has saved my ass a few times. good luck. i don;t recommond using it in the same tank as you would normaly annodize in.
my setup for ths uses a 2 gallon bucket. and about 1/4 of a gal of sulfuric and about a galon and a half of destiled water. i use a cathode thats is rufly 5x7. your not trying to ano just trying to desolve the metal. and run it at a constent 12volts. when you do this you will see bubbles coming from where the metal is that means the metal is being actacked. you should check it about every 5 minutes to see how it is going. |
| PLATING POT METAL............... | 48Buick | Plating Pot Metal | 31 | 08-29-2007 11:40 AM |
| Part is 1/2 blue 4A, 1/2 Deep red. red fades when boiled | frubino | Anodizing Questions | 1 | 07-27-2004 01:56 PM |
| A few question to help a beginner | Cyberave68 | Anodizing Questions | 6 | 06-08-2004 08:53 PM |
| Looking for masking tape recomendations. | chcarver | Metal Polishing Questions | 0 | 03-06-2003 02:51 PM |
