It is a Pyramid. Looks good to me. Just thought I would check with the pros on this.
Input: 110/60 Hz Input Current: 230mA @ 0A Load 2.21A @ 5A Load Output Current: 0-5A Adjustable Output Power: 0-30V Adjustable Fine & Coarse Voltage Adjustments for Accurate Settings Ripple: 50mV Peak to Peak Max @ 5A Load Load Regulation: ±2% Short Circuit Protection Overload Protection with Reset Button Dual Gauges (Current/Voltage) Safety In-line Jack Positive, Negative and Ground Output Terminals Complete with Test Leads and Manual Suitable for Scientific & Technical Applications Dimensions: 11.5"L x 9"W x 4.75"H I also have a small question. When you do not know the part's size in ft^2, is it safe to feed it a small current and watch the voltage for par? Thanks. |
That power supply will do fine.
It will take less work in the long run if you take a stab at calculating the surface area. You will get close enough in practice if you wrap the work with a piece (or pieces) of paper; trying not to overlap the paper, and covering as much of the surface as you can, inside and out. Then unwrap it and measure the paper. The approximate area is the length x width of the paper. If your measurements were in inches, divide the result by 144 to yield the area in sq.ft. |
| anno power supply | jasonboulanger | Anodizing Questions | 2 | 01-07-2005 06:48 PM |
| power supply | MrDmB | Other Metal Finishing Questions | 0 | 02-27-2004 03:32 PM |
| Is this a good CC power supply?? | Fudd | Anodizing Questions | 2 | 12-15-2003 06:17 PM |
| New power supply? | Tim Wiltse | Anodizing Questions | 7 | 10-23-2003 06:26 PM |
| Anodizing Power Supply Q's | jnbsystems | Anodizing Questions | 7 | 10-02-2003 11:33 PM |
