  #21 (permalink)
Old 03-31-2004, 03:19 PM
M_D M_D is offline
M_D
It's the 2XXX alloys that I find build a heavier layer of smut in lye based solutions.
I know the 2XXX builds less film thickness compared to other alloys for a given time, so I'm not 100% positive why less time compared to 6061 gives good results. If I anodize 2011 for the same time I do 6XXX series, it tends to get speckles in the dye, and a smutty coating.
I am not following the LCD formula either for the bulk of our anodizing, not because it doesn't give good results, but because of time considerations mainly. I am doing 6XXX series at 8 amps CD for 75 minutes in 2.5:1 solution with good results, and the 2011 amps CD for 60 minutes.
I want to experiement more too, but haven't had time. So, I am sticking with what is working for me now. Fibergeek, I would like to hear the results of your findings if and when you are ready to reveal them.
  #22 (permalink)
Old 03-31-2004, 10:00 PM
Hey, nothing succeeds like success.
It won't be if you hear about it, it will be when.
Flash Copper Problem gwjohnso Plating Pot Metal 12 02-28-2007 12:41 AM
Anodizing Problem???? Cyberave68 Anodizing Questions 3 03-31-2004 03:03 PM
Nitric Acid/Desmut problem....Help Easttex Anodizing Questions 1 02-19-2004 11:59 AM
Static electricity problem Gasit51 Metal Polishing Questions 3 02-16-2004 10:43 PM
BEWARE!!! Problem Plating Car with Metallic color paint! GoldiesPlating Electroplating Questions 0 08-29-2003 10:29 PM
