Old 02-09-2004, 03:32 PM
Sid03
Default need help finding problem....
I did two pieces yesterday at the same time. One I dyed orange and it turned out fine. The other I dyed red.....
While dying and after removing from teh dye bath(while still wet) it looks 100% fine. When it started to dry it got darker spots on it.....dull looking compared to the other area's. You can rub your finger over the area and it will change color and you'll get red chalky powder on your finger very easily. Any idea's offhand? I can post teh total spec of the whole process I did if needed later, but everything is the same and I just had a piece turn out in red perfect last week. My final PAR turned out to be 2.66ohms. Parts werent sealed so thats not a variable. The part was in the red dye alittle longer then normal....about 20 minutes, if that would effect anything. Thanks!
Old 02-09-2004, 08:09 PM
Sid03
no ideas? This randomly happens to me all the time and I would LOVE to know exactly why. I can take pics if needed....and if I can host them somewhere.
Old 02-09-2004, 10:10 PM
If this "randomly happens all the time" something is marginal. Since none of us can see what you are doing, maybe you should lay out your entire process. BTW, does this only happen with red?
Old 02-09-2004, 10:20 PM
M_D M_D is offline
M_D
Maybe you could post pictures to the album area? If you do that and list the entire process in detail, maybe someone will have answers that will help you. What is your red dye ph now? It will change sometimes, so just because it was ok, don't assume it is now.
Old 02-12-2004, 02:03 PM
Sid03
i emailed the pics to caswell, i believe they will be posting them for me.
Old 02-12-2004, 03:32 PM
mcaswell's Avatar
Caswell Inc Founder
Have A Web Site?
Old 02-12-2004, 07:19 PM
NeoMoses
Looking at those pics, it doesn't immediately appear that anything is seriously wrong.
You state, "When it started to dry it got darker spots on it.....dull looking compared to the other area's." That's normal, an unsealed anodized surface will be somewhat rougher than the original part, and when the dye starts to dry, the dry areas will appear 'dull' while the wet areas will appear shiny.
"You can rub your finger over the area and it will change color and you'll get red chalky powder on your finger very easily." Again, that's pretty normal. Rubbing your fingers of a dry, unsealed part will allow you to pull dye out of the pores, eventually changing the color. You can also leave oily fingerprints on the part if you touch it between the dyeing and the sealing step.
Did you seal this part, or just let it sit? If this part was acting this way after 15-30 minutes in the sealer, then there is likely a problem with excessive pore size not allowing the part to fully seal. That's usually a function of your anodizing parameters (Current density, electrolyte concentration, temperature...)
From looking at the pictures, it appears there is an anodized layer and the part did not lose electrical connection. What was the surface finish before putting the part in the tank? Did you alkaline etch these parts (Lye or Desmut) before anodizing?
  #8 (permalink)
Old 02-12-2004, 08:37 PM
Sid03
Caswell degreaser and desmut used before ano.
What you mentioned is in no way normal. I can take parts that I dont seal and rub and nothing comes off. It's not like im really rubbing on this part....one pass of the finger gets your finger red like in the pic. When I gave the wet/dry comparison, i meant when the part was completely dry. The part was completely dry in the pics...had been sitting for days. You can see how some areas are duller looking, and the chalky residue rubs off ALL of the areas very easily.
Any ideas?
  #9 (permalink)
Old 02-13-2004, 07:59 PM
M_D M_D is offline
M_D
This may or may not be the problem: It may be the part is anodized for too long or at too high of a rate. If you have extra test pieces of aluminum you might try experimenting with times. As far as why the orange looked ok and the red didn't, I know different colors have their own distinct characteristics, although I haven't used orange and can't comment on it specifically.
  #10 (permalink)
Old 02-13-2004, 11:26 PM
whistule
I would have thought the colour rubbing off wa because it was a residue on the surface that had not been absorbed into the pores. I had one or too problems like this when starting out and in my case I didn't have enough agitation in the dye tank and the dye was slightly too concentrated.
Flash Copper Problem gwjohnso Plating Pot Metal 12 02-28-2007 12:41 AM
Anodizing Problem???? Cyberave68 Anodizing Questions 3 03-31-2004 03:03 PM
Nitric Acid/Desmut problem....Help Easttex Anodizing Questions 1 02-19-2004 11:59 AM
Static electricity problem Gasit51 Metal Polishing Questions 3 02-16-2004 10:43 PM
BEWARE!!! Problem Plating Car with Metallic color paint! GoldiesPlating Electroplating Questions 0 08-29-2003 10:29 PM
