Go Back   Caswell Inc. Metal Finishing Forums > Anodizing Questions
Connect with Facebook
Closed Thread
Old 03-12-2004, 07:15 PM
elton10
Default clearance between parts and cathode
I've seen a figure somewhere calling for 3" clearance between the part and the cathodes and sides of the tank. Is there a similar clearance needed between each part? What would be the max capacity(in sq. in) of the LCD kit tanks?
thanks in advance
Elton
Old 03-12-2004, 09:57 PM
That's 3" clearance between the part(s) and any cathode surface.
The parts (if you are doing more than 1 at a time) can be closer to each other, but should not touch. Since the shape of the parts can't be defined, a spec for max part capacity in the tank can't be defined either. In practice, the total surface area of the part(s) should be less than the total surface area of the cathode(s), and still conform to the 3" rule.
Old 03-13-2004, 12:29 AM
elton10
Default clearance
Fiber
Thanks for that info. So I gather capacity is more a function of cathode area than electrolyte amount? That is of course taking in to account the 3" clearance..
How are most folks dealing with the anode shadow on dyed parts?
Old 03-13-2004, 12:33 AM
elton10
Default LCD Cathodes
what is the total surface area of the cathodes in the LCD kit?
Old 03-13-2004, 12:40 AM
elton10
Default cathode area
I looked at the contents list of the kit and I think I may have answered my own question re: cathode area... Are the '8"x8" GP plates' the cathodes?
Old 03-13-2004, 02:33 AM
M_D M_D is offline
M_D
Default Re: cathode area
Yes. You could always add cathode are, but one other thing that can limit the capacity is this: you can only put so many amps into a given sized tank in a given period before the current raises the temperature too high for good and predictable results. If you anodize a part with .5 square feet for example, and find x amount of minutes at 2.25 absolute amps (4.5 amps per square foot) gives you the results you desire, and then try a load of 3 square feet with 13.5 amps, the results probably will not be as good. That has been my experience anyhow.
If you stabilize the electrolyte temperature with some sort of cooler, that is another matter. I have seen there are additives that can help minimize or extend the practical temperature limits, but don't have any experience with that yet.
Old 03-13-2004, 11:44 AM
elton10
Default cathodes
MD
Thanks
The temp limits are 65 -75 degrees F?
I guess what i will do is work up the size of batches until I reach the point where the temp gets beyond.. I did notice that commercial Type II anodize set-ups do have some cooling apparatus with them..
thanks again for the info
  #8 (permalink)
Old 03-13-2004, 10:48 PM
elton10
Default cathodes
Just exactly what are the 8"x8" GP plates.. what is GP..I thought anodizing used lead or aluminum cathodes?
  #9 (permalink)
Old 03-14-2004, 02:11 AM
GramSlam is on a distinguished road
GP Plates are lead cathode plates.
Closed Thread
using aluminum as a cathode scocklin Anodizing Questions 19 03-31-2007 01:18 AM
Cathode size R-Wells Anodizing Questions 7 04-22-2006 07:18 PM
Distance to cathode PeterM Anodizing Questions 2 10-01-2004 02:43 AM
Titanium Anodizing ron423 Anodizing Questions 4 08-23-2004 05:09 PM
cathode hangers wallyaction Electroplating Questions 3 08-31-2002 11:36 AM
