+ Reply to Thread
Results 1 to 5 of 5
Thread: work area vs. cathode area
  1. #1
    Default work area vs. cathode area
    Is there some ideal ratio or rule-of-tumb ratio between the work area and cathode area for anodizing? Or is just that the cathode area should be larger than the work?
    Share with Facebook
  2. #2
    Join Date
    Jul 2003
    Posts
    537
    If you are using the anode/cathode ratio to provide some current limiting (not recommended) then it would matter.
    The simple rule for this in LCD anodizing is to have the cathode area larger than the anode area.
    If you are using CC mode, any differences in the electrolyte conductivity caused by this ratio are automatically compensated for. This is one of the many advantages a current source has over a voltage source for anodizing or electroplating.
    Share with Facebook
  3. #3
    Fibre
    Thanks. Actually Im NOT using a CC supply but I plan on mimicking CC by keeping a constant check and adjusting voltage.
    We've got one of Caswell's 25A plating rectifiers but will likely get the 20A CC as soon as they get them in.
    Share with Facebook
  4. #4
    Join Date
    Jul 2003
    Posts
    537
    OK. That should work.
    Share with Facebook
  5. #5
    Great and thanks again for the info
    Share with Facebook
+ Reply to Thread
Thread Information
Users Browsing this Thread
  1. Calculating Surface Area, the Easy Way.
    By PrecisionPB in forum Anodizing Questions
    Last Post: 05-28-2005, 02:56 PM
  2. Anodizing without knowing surface area?
    By sbpoole in forum Anodizing Questions
    Last Post: 01-06-2005, 07:09 PM
  3. Need help on what area to calculate to determine my amperage
    By krsimulis in forum Electroplating Questions
    Last Post: 06-12-2004, 03:02 PM
  4. clearance between parts and cathode
    By elton10 in forum Anodizing Questions
    Last Post: 03-14-2004, 01:11 AM
  5. Surface Area vs. Current
    By shorton in forum Electroplating Questions
    Last Post: 11-06-2002, 11:36 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
