+ Reply to Thread
Results 1 to 4 of 4
Thread: anodizing a motorcycle engine
  1. #1
    Default anodizing a motorcycle engine
    Hello All,
    I was in the middle of rebuilding my first bike engine when I stumbled upon Caswell.com. I was immediately intrigued and would like to know if it's possible to anodize my engine block. I'm not sure of the surface area of the block, but it's a 750cc '83 honda sabre if that helps. (The block splits in half, so I would only anodize half of it at a time.) A few of my questions are as follows:
    1. how can I find out what type of aluminum alloy the engine is made of?
    2. can the Caswell masking agent be used inside the engine and cleaned easily afterwards, so as to not ruin precise measurements?
    3. approx. how big of a rectifier would I need to anodize the engine block?
    4. will the anodized layer be able to withstand the heat of an engine for prolonged periods?
    If anyone could shed some light on any of these questions or direct me to the correct place to find the information it would be much appreciated.
    Share with Facebook
  2. #2
    Join Date
    Jul 2003
    Posts
    537
    Since your motorcycle engine is air cooled, by design has lots of surface area. You will certainly need a large setup and a very large power supply. If your only doing this one engine, it will be a lot cheaper to have it done commercially.
    1. Ask Honda, the commercial anodizer will want to know this too.
    2. I don't know, Caswell will have to answer that.
    3. That depends entirely on the surface area of each engine block half. You can forget any size battery charger.
    4. When I was young and indestructible, I had a '72 Kawasaki Z1. That 900cc 4 cylinder DOHC "road rocket" had a black anodized block.
    Share with Facebook
  3. #3
    Thank you. I will give Honda a call and check local anodizing shops for prices.
    Share with Facebook
  4. #4
    customandsound Guest
    it is some kind of cast aluminum.... i melt them down from time to time .. for sand casting's .... good alloy to !!!!!!
    Share with Facebook
+ Reply to Thread
Thread Information
Users Browsing this Thread
  1. Polishing cast aluminum motorcycle engine cases.
    By Mutt in forum Metal Polishing Questions
    Last Post: 07-16-2005, 11:46 PM
  2. Polishing a motorcycle engine
    By mpgcustoms in forum Metal Polishing Questions
    Last Post: 06-11-2005, 12:58 AM
  3. Color depth vs. anodizing time
    By NeoMoses in forum Anodizing Questions
    Last Post: 02-03-2004, 09:06 PM
  4. Motorcycle Engine polishing
    By tomlando in forum Metal Polishing Questions
    Last Post: 01-17-2004, 03:28 PM
  5. Anodizing different alloys
    By TONYZ in forum Anodizing Questions
    Last Post: 11-02-2003, 01:31 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
