Hi all!
Would it be ok to use a cheap stainless-steel pot for the Nickel Acetate sealing stage, as I intend to use an external heat source? I've read that only 316 should be used, but does anyone have an experience of using other types, as the cheap pot is almost certainly not 316? Thanks for any help you guys can give! -Tone. |
I could only get 8 litre (8.5 US quarts, I think) stockpots, but they'll be more than enough for what I need right now. I also got a neat little electric stove (about the size of a small briefcase) that gets the water boiling in about 30-40 mins. Looks like quite a neat & tidy setup, now I'm just waiting on my PSU. Cant wait!
Thanks again guys! |
When using an external heat source such as a stove the stainless pots are a natural choice. When using the submersible heaters plastic buckets work better in a sense, because the plastic doesn’t loose as much heat as metal and that makes it easier to heat the solution.
| Chrome on stainless steel | Fick | Other Metal Finishing Questions | 3 | 07-05-2005 12:27 PM |
| blackening 303 stainless?? | toku58 | Other Metal Finishing Questions | 0 | 01-27-2005 02:45 PM |
| Sealing | RPE | Anodizing Questions | 1 | 04-08-2004 02:39 AM |
| Stainless Steel pot + Dye = Poor results? | NeoMoses | Anodizing Questions | 2 | 01-08-2004 03:56 AM |
| Stainless Steel Help, Please | rbkemp25 | Metal Polishing Questions | 4 | 06-21-2003 06:59 AM |
