If you anodized two identical parts together, except that one was suspended from aluminum, and the other titanium, the titanium one would receive less current. Why? because aluminum is a better conductor than titanium. Mixing titanium and aluminum adds another variable and provides no benefit.
I can provide a simple answer to your case.
If you are suspending the work from wires; what's important here is that the surface area of the wires is much less than the surface area of the work, there won't be much of a difference between aluminum wire and titanium wire. The titanium wire will drop a bit more voltage than aluminum wire, but a CC power supply will compensate for this automatically. Nothing to worry about. If you had two pieces of work in the tank together; one with Al wire, and the other with Ti wire, the CC power supply won't know which to believe, so it will strike a compromise. This situation gets much different with racking, since the surface area of the rack is often larger than the total surface area of the work, so the rack is setting the current density, not the work. |
Use a smaller gauge wire. As an example; 14 AWG is 0.062" dia., assuming a piece 6" long in the electrolyte:
Surface Area (SA) of a cylinder is Pi x D x L (ignoring the area of the end of the wire) SA = 3.14 x .062 x 6 = 1.17 sq. in. That's about .008 sq.ft. your part is that small? If you used 18 AWG (.038" dia.) The SA would reduce to 0.71 sq.in. (.005 sq.ft.). |
The violet colored part in the pic above had about .0002 sq.ft. If I used .062" wire and only had 1.5" length in the electrolyte then the wire and part would be close to equal. I have been using alum wire and a CV setup to do these so far but would really like to make some reusable Ti fixtures to hold them. The small alum wire breaks after the first use.
| Titanium Anodizing | ron423 | Anodizing Questions | 4 | 08-23-2004 05:09 PM |
| Use of Titanium. | usao | Anodizing Questions | 10 | 05-17-2004 11:28 PM |
| Series 1100 Aluminum Wire | Fibergeek | Anodizing Questions | 2 | 01-27-2004 12:29 PM |
| Titanium anodizing | lorenzo | Other Metal Finishing Questions | 1 | 06-27-2003 09:56 AM |
