Old 06-24-2004, 02:35 PM
sgunn911
Default Anodizing with a rectifier
In my experience with using a CC rectifier, I found that sometimes the "90 minute rule" doesn't seem to get the anodize to PAR. Can you just watch the voltage and stop anodizing when you see the voltage start to climb to keep the current constant meaning that PAR has been reached?
Also, in a previous topic "finishing techniques" I was confused about finished after anodizing because the anodizing manual says you can polish the piece with a loose cotton wheel and white compound.
Old 06-24-2004, 06:28 PM
I wouldn't call the "90 minute Rule" a rule, and I wrote it, its a guideline.
4.5 A/sq.ft. is the center of the published LCD range; which is 120 min at 3A/sq.ft. on the low end, to 60 minutes at 6A/sq.ft. on the high end. These times are based on the "720 Rule" for anodization time, and are intended to produce a layer 0.5 mils thick. A good general number for Type II intended for dyeing. PAR can be illusive if your operating conditions aren't right, I would suggest that you follow the 720 rule.
Sanding/grinding, or polishing an anodized layer can be hazardous to the layer if the work can flex or oilcan, just like with any other thin ceramic.
Is the 20 amp CC rectifier big enough for this? bbqboyee Anodizing Questions 4 04-01-2005 02:23 PM
CC Rectifier PeterM Anodizing Questions 3 09-23-2004 06:09 AM
Color depth vs. anodizing time NeoMoses Anodizing Questions 17 02-03-2004 09:06 PM
Complicated things for a total anodizing newbie. taylorm Anodizing Questions 2 01-19-2004 10:50 AM
Anodizing different alloys TONYZ Anodizing Questions 2 11-02-2003 01:31 PM
