+ Reply to Thread
Results 1 to 5 of 5
Thread: Part not anodizing/Partially anodizing
  1. #1
    Default Part not anodizing/Partially anodizing
    I have an LCD anodizing kit and it works occasionally, but the usual problem im having that the parts arent taking dye, which leads me to beliebe that they are not anodizing. Tiny bubbles come off the part when it is in the tank, and when I take the part out it has a grey coating on it (the coating wipes off when i touched it).
    Im really confused on calculating all the PAR stuff, so ive just been kinda winging it as far as voltage and times go.
    Can somebody explain this for me?
  2. #2
    Join Date
    Nov 2001
    Location
    Lyons, NY USA
    Posts
    1,795
    You haven't given us much to go on here.
    You need to fill in a PRS troubleticket, so we can see exactly what you've done. If you aren't controlling the amps properly, you'll not get good results.
    Have A Web Site?
  3. #3
    Join Date
    Jul 2003
    Posts
    537
    If you just "wing it" you will fail most of the time.
    The 720 Rule has been shown to accurately predict anodization time. I recommend that you use this instead of PAR.
    720= ASF x minutes / mils.
    ASF = Amps per square foot, which is the current density.
    Minutes = minutes of anodization time.
    Mils = Anodize thickness in mils (1 mil is 0.001 inches)
    The anodization temperature must be held to between 70 and 75 deg. F. the 720 Rule will be off if its not, other bad things can happen too.
    The Baseline for LCD is 4.5 ASF for 90 minutes. This is intended to produce an anodize layer a little over 0.5 mils thick, which will dye very well.
    Some examples:
    The surface area is 1 sq.ft., the current density is 4.5 A per sq.ft.
    720 / (4.5 / 0.5) = 80 minutes for 0.5 mils thick.
    The current you would apply is:
    4.5 ASF x 1 sq.ft. = 4.5 Amps.
    The surface area is 36 sq.in. (36 / 144 = .25 sq.ft.) the current density is 6 ASF (the high end of the LCD range).
    720 / (6 / 0.5) = 60 minutes for 0.5 mils. thick.
    6 ASF x 0.25 sq.ft. = 1.5 Amps.
    You can form a thicker layer by anodizing longer, but if the temperature in the tank gets higher than 75 deg. F, dissolution effects will enlarge the anodize pore size and trouble starts. Forming a layer much greater than 0.5 mils should not be attempted until you can successfully anodize and dye at 0.5 mils. For dyeing purposes; there is no point going beyond 0.7 mils, this is because the dye (any dye) won't penetrate any deeper than 0.7 mils.
    Edited to correct the first equation.
  4. #4
    Join Date
    Dec 2003
    Posts
    153
    sadly enough, im kinda lost here. In this example.....
    if you worked those numbers out backwards it doesnt work....
    720= ASF x minutes x mils
    720= 4.5 x 80 x 0.5 <---that isnt correct
    What am I missing? I couple more examples of the 720 rule would be appreciated, I would like to try it out this weekend.
  5. #5
    Join Date
    Jul 2003
    Posts
    537
    Sid,
    I arranged the first equation wrong, it should have been
    720 = ASF x minutes / thickness in mils
    The second equation to solve for anodizing time is correct.
    Look at it this way; since coating thickness is proportional to current density (ASF) and time. This means that if you half the time you half the coating thickness.
    Good catch, thanks.
+ Reply to Thread
Thread Information
Users Browsing this Thread
  1. Part is 1/2 blue 4A, 1/2 Deep red. red fades when boiled
    By frubino in forum Anodizing Questions
    Last Post: 07-27-2004, 01:56 PM
  2. A few question to help a beginner
    By Cyberave68 in forum Anodizing Questions
    Last Post: 06-08-2004, 08:53 PM
  3. "Hard" Anodizing vs. "normal"; differenc
    By dagobert in forum Anodizing Questions
    Last Post: 02-26-2004, 11:24 PM
  4. Color depth vs. anodizing time
    By NeoMoses in forum Anodizing Questions
    Last Post: 02-03-2004, 09:06 PM
  5. Anodizing different alloys
    By TONYZ in forum Anodizing Questions
    Last Post: 11-02-2003, 01:31 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
