I have had very little experience doing 2011. I took in two Shockers (paintball markers) that are almost entirely constructed from 2011. In the past I have had problems with Chippley Custom Machine feed necks,constructed of 2011, that didn't come out very well (pre LCD days.) I noticed in the album section that SX Paintball had a pic up there of a shocker.....Any probs in the tanks with it? These markers have to be right. One will be polished (orange with black accents)and the other will be dusted (blue to black Fade.) Any ideas or tricks would be appreciated......
Thanks, Easttex |
We do quite a few pieces in 2011. I like the way it machines in the turning centers, the chips are short and don't tangle in the tools and around the part which can cause a poor machine finish. But, I am not fond of the anodizing characteristics, 6011 is much nicer. For one, everything being equal, the 2011 will be duller. But if you have a nice polish it should still look quite nice if done correctly.
I don't know what you normally use to clean with, but if the part has been freshly stripped and polished a good degreasing to where the water sheets should be adequate prep. Leaving 2011 in too hot of cleaner too long hurts the final appearance, as does etching in lye. Our 2011 parts are completely machined, and we get the nicest results by just degreasing them at 140ยบ or so in SP cleaner until the water sheets. It the parts darken at all, we place them in warm desmut only long enough to brighten them up. In any case, if any of the prep leaves a dark dull look, aoppearance will suffer even though the desmut seems to clean them up. I have found that 50-60 minutes at 10 amps CD works best for us, going on ease of dying and color depth, in addition to retaining a decent gloss when done. But that can vary according to part prep and desired color depth, if you don't need a real dark color depth less time should leave a cleaner and brighter finish. |
| Some newbie questions... | kiwijetpilot | Anodizing Questions | 16 | 03-12-2005 08:18 PM |
| Questions on Fibergeek's Anodization Curves 1 of 3 | scocklin | Anodizing Questions | 1 | 12-05-2004 08:54 PM |
| Damaging 6061-T6 by PCing | KurtXP | Powder Coating Questions | 19 | 10-30-2004 10:43 AM |
| Techno-Geek Questions | edclark | Electroplating Questions | 3 | 01-14-2004 08:01 PM |
| Aluminum or Alloy | radioactive | Metal Polishing Questions | 2 | 12-16-2002 10:23 PM |
