  #11 (permalink)
Old 09-03-2004, 08:04 AM
Zouky
Hey Sgunn911,
I am interesting to see your anodizing work on your copter parts.
Are you using anodizing color to light up your heli parts in dark?
Thanks,
Andy
  #12 (permalink)
Old 09-26-2004, 02:27 AM
GramSlam is on a distinguished road
You can anodize parts to look white. But it's still not white....
To do this, you can use a very fine grit silica blasting media (80-100). The blasted surface will cut down on the light reflected from the surface. That is the closest thing you will ever see to white.
hope that helps
  #13 (permalink)
Old 09-27-2004, 12:38 AM
Rit fabric dyes may have a color that suits you, but they are not UV stable, and may fade in the sun.
  #14 (permalink)
Old 09-29-2004, 01:01 PM
kickn
I've very interested in finding some UV reactive dyes - anyone seen anything like that?
  #15 (permalink)
Old 10-05-2004, 06:14 AM
Zouky
Can fluorescent dye make the part visible in dark? Or what is the purpose of the fluorescent dye?
Andy
  #16 (permalink)
Old 10-05-2004, 08:22 AM
kickn
UV reactive dye would make it visible in the dark with the aid of a blacklight
  #17 (permalink)
Old 10-12-2004, 12:15 AM
ase618
caswell im interested in flourescent green and orange also. thanks
  #18 (permalink)
Old 10-18-2004, 02:11 PM
fmahone
Default other dye source
I have heard of some people using fabric dyes for anodizing. they are organic, like regular aluminum dyes, but some fade rather easily.
I also do tie dye as a hobby and found craft stores sell fabric dye in powder form. Also, Daharma sells a lot of dyes and has a wide variety of colors. Check their web site.
The problem with true florescent dyes is the particle size is large, you will have problems getting enough dye in to the small pores to do a good job.
The florescent dies listed at Caswell are not really responding to u.v. light,
but take the appearance of glowing.
