i did ask in my original post if it could be bad sealant.......meaning outdated, wrong Ph, etc.
I came across this in some notes I saved off the forum........
1. The fact that you can get all other colors to work has no relevence to red.
2. The dye pH MUST be between 5 & 6
3. Do NOT use LT Sealer. Use the regular sealer.
4. Maintain the sealer at a rolling boil
5. Make sure the nickel acetate powder is at 1 oz per gal di water.
If the sealer is murky = pH is too high Must be 5.5-6
If these things are not adhered to, RED dyes will bleed out.
THATS why I was thinking it wasnt an actual ano problem. The sealant was old(about 5 months) and wasnt at a boil. Also, the other colors on this part seemed to be fine, although they are not rubbed as much as the red was.
