I don't know about the Crystal type, but Simple Green will work as a preliminary degreaser, but I've found that it still seems to leave something behind on the surface of the aluminum that screws up anodization to some extent. This has occurred even after it passes the water-sheeting test. I think it may be the surfacant they add to it, but I'm not sure. What I do is the heavy degreasing with the Simple Green to remove any polishing compound, etc., then use a little Caswell's SP degreaser as a final degreaser.
| Green Chromate | steveparson | Electroplating Questions | 0 | 07-15-2005 12:19 PM |
| green dye | jamerson | Anodizing Questions | 4 | 06-26-2005 01:23 PM |
| simple green...... | Sid03 | Anodizing Questions | 3 | 03-18-2005 12:19 AM |
| SP Degreaser | aermakov@rogers.com | Electroplating Questions | 5 | 05-13-2003 09:55 PM |
| What degreaser are you using? | fosgate99 | Metal Polishing Questions | 2 | 11-05-2002 10:57 PM |
