Old 09-22-2004, 04:08 AM
sgunn911
Default Graphics
I am producing ,any graphics on parts using paint masks. The only problem is the adhesive left behind. Any suggestions?
Old 09-23-2004, 03:01 AM
Same problem I'm having right now. I have found rubber cement works pretty good as a liquid mask. Pre-cut masks like flames and such (rc hobby shops) make nice crisp lines, but leave residue, especially the positioning backer.
I saw a liquid mask at Caswell, but haven't tried it yet.
Caswell, that stuff work well and peel off clean after ano, and between colored dyes?
I've seen Gucci patterns in ano, digital camo, all kinds of cool stuff, but nobody is willing to say how... Anybody?
Old 10-25-2004, 07:43 PM
jagrc
Send a message via Yahoo to jagrc
I have had great sucess using vinyl masking on my anodizing. Here are some samples of what I have done with it. Please excuse the poor picture quality.
Old 11-01-2004, 01:43 PM
mudwhump
I have the same question... I would like to be able to dye parts with multiple colors, using one mask, and then another. The problem is that anything that touches the freshly anodized surface with adhesive (even the low tack stuff) causes it to not take dye. I believe the adhesive is blocking the pores. If you wipe the adhesive off with alcohol or acetone you get the same result. The liquid mask doesn't seem like the best answer. How are you supposed to apply the mask without having some sort of stencil? Anyway, if anyone has a process that they use to successfully apply multiple colors to an anodized surface, I would appreciate some pointers. Thanks
Tim
Old 11-15-2004, 08:51 PM
Pmonhollon
okay this is the method I use over and over again. #1 anodize piece as you normally would#2 dye the piece what ever color you want your graphic to be #3 apply the graphic mask #4 bleach the piece in approx 1 quart bleach to one gallon water #4 rinse thouroughly under the tap #5 If any discoloration is left dip the piece in the ano bath. it usuall clears it right up. #5 rinse and repeat prosess from step 2 as many times as nessecary.
As far as applying masks I always try to use vinyls. this is my method. #1 get your vinyl UNweeded and cut out around the design if you are using rc masks with alot of stuff you dont want to use at this time. #2 spray the top side of the mask with contact adhesive. I use DUCO brand I get at walmart cause its cheap. #3 weed the vinyl being careful not to touch the backing with the adhesive. I usually use tweezers and an exacto knife. # 4 cover the vinyl in clear plastic (I have cut pieces of freezer bags to do this) #5 Carefully remove backing and apply mask using the clear plastic now glued to your mask. Agood rule of thumb is once the mask touches the piece DONT try to remove it or you will have a flaw where it touched. use the process above and when you are done pull all the masks off and drop the piece in your boiling sealer and in a few minutes you can either rub the adhesive off with a clean rag or go ahead and seal the part and wipe it off with some laquer thinner when you are done. I always wash my work with hot water and dawn dish soap after everything is done and I never have any residues left.
Old 11-16-2004, 08:05 PM
lastone75
Send a message via AIM to lastone75
wouldn't a vynil cutter work better. only reason i'm asking is cause i have one and haven't realy thought of using it for this perpose till now.
the designs you could do with a vynil cutter would be sick.
Old 11-16-2004, 08:32 PM
Pmonhollon
Hell yeah, I am trying to fit one into my budget. A vinyl cutter woul give you pretty much endless possibilities for designs and stuff.
  #8 (permalink)
Old 11-16-2004, 09:13 PM
lastone75
guess i have to try it. my biggest problem is i have to set it up on the kitchen table to run it. it's has issues running with xp. so i run it off an old laptop.
  #9 (permalink)
Old 11-21-2004, 06:08 PM
Pmonhollon
this was done using the above mentioned method
  #10 (permalink)
Old 11-21-2004, 06:10 PM
lastone75
that came out awesome
adding graphics to powder coating snotboards Powder Coating Questions 5 10-08-2005 12:24 AM
panel graphics fum Other Metal Finishing Questions 3 05-17-2004 03:25 PM
