I have a question about the rectifier issue. I know that a CC rectifier is needed for anodizing, but whats the possibilitys with a none CC rectifier?
The problem is that i have 2 rectifiers already and none of them are CC. One of them has 2 knobs (for voltage, and ampere) still its not CC. If I would do a LCD-anodizing and act as CC myself, that is adjusting the Ampere by hand during the process, would that be possible. I could maybe connect a Ampere-meter to the system and check that the ampere is in the right range by adjusting it? The thing is that I only would like to anodize one small part in a system a build pretty rarely, so i could spend some time adjusting, if that now is possible rather than spending money on another rectifier Thanks in advance |
You could also add a quick-n-dirty current control using an LM117 family voltage regulator wired as a current limiter.
A single chip & single resistor (or potentiometer) allows you to set current at whatever you need, up to 5 amps. See the PDF data sheets: http://www.national.com/ds.cgi/LM/LM117.pdf - 1.5A http://www.national.com/ds.cgi/LM/LM150.pdf - 3A http://www.national.com/ds.cgi/LM/LM138.pdf - 5A |
Thanks alot Fibergeek and Seanc. Im going to check up those regulators and try them out. Otherwise i could go with the manual adjustment, but yes - not needing to stand by the process and turn a knob every now and then would be nice.
| Is the 20 amp CC rectifier big enough for this? | bbqboyee | Anodizing Questions | 4 | 04-01-2005 02:23 PM |
| Rectifier Question | danahenderson | Anodizing Questions | 2 | 03-09-2004 04:57 PM |
| hard chrome rectifier | elboriqua | Electroplating Questions | 1 | 11-04-2003 08:44 PM |
| My rectifier died :( | SS65 | Electroplating Questions | 1 | 03-22-2003 06:01 PM |
| [b]Epsco 3 AMP Rectifier and Copy Chrome[/b] | gwjohnso | Electroplating Questions | 1 | 03-08-2003 10:11 AM |
