+ Reply to Thread
Results 1 to 2 of 2
Thread: Calculating the surface area?
  1. Calculating the surface area?
    Hello,
    I have a quick question.
    Does anyone know if you can accurately calculate the surface area of the parts in the anodizing tank using the resistance between the parts and the cathodes?
    I am using a total of 256 in² lead cathodes. The parts I anodize have many little spots that are difficult to measure.
    Share with Facebook
  2. Join Date
    Jul 2003
    Posts
    537
    It seems reasonable to think so, but there are two problems.
    1. Bare aluminum will have an extremely low surface resistance, way too low for any common Ohm meter. A conductance measurement would be required.
    2. Ionization effects; most liquids ionize when current flows through them, resulting in all sorts of variations in a resistance or conductance measurement. A repeatable measurement is next to impossible unless a liquid that won't ionize is used. Mercury would work, but this isn't practical.
    Share with Facebook
+ Reply to Thread
Thread Information
Users Browsing this Thread
  1. Calculating Surface Area, the Easy Way.
    By PrecisionPB in forum Anodizing Questions
    Last Post: 05-28-2005, 03:56 PM
  2. Anodizing without knowing surface area?
    By sbpoole in forum Anodizing Questions
    Last Post: 01-06-2005, 08:09 PM
  3. surface area
    By txturbo in forum Electroplating Questions
    Last Post: 06-05-2003, 03:04 AM
  4. surface area for electroless plating
    By tepece in forum Electroplating Questions
    Last Post: 02-09-2003, 08:54 PM
  5. Surface Area vs. Current
    By shorton in forum Electroplating Questions
    Last Post: 11-06-2002, 12:36 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
