And just a side note on the firguring of rack size and the 720 Rule- Yes, you will need to figure in rack size only if you are doing eletrolytic color. Some of our rack designs have been over 1,000 ft2 alone per 30' load bar. |
Hi,
I have put up with a new plant of hard anodizing. Please can u guide me in how to get the best results for my anodizing. I am anodizing utensils but i am getting gray color anodized. I need jet black. please guide me on the bellow question: - 1. What temperature shoult i anodize. 2. What should be my acid mixture(and how pure should be my acid). 3. What volts and amps should i anodize . 4. What other chemicals can i us. 5. How should i do the sealing. my tank size is:- length=13ft Width= 3ft Hight=3.5ft please guide me. thanking you manish |
Hi,
I have put up with a new plant of hard anodizing. Please can u guide me in how to get the best results for my anodizing. I am anodizing utensils but i am getting gray color anodized. I need jet black. please guide me on the bellow question: - 1. What temperature shoult i anodize. 2. What should be my acid mixture(and how pure should be my acid). 3. What volts and amps should i anodize . 4. What other chemicals can i us. 5. How should i do the sealing. my tank size is:- length=13ft Width= 3ft Hight=3.5ft please guide me. thanking you manish n jain |
CC is controlled current, and CV is controlled voltage. If you know the titration levels of your ano bath, you can calculate the volts for CV operation (most commercial set up use this method). What you are asking for are closely guarded secrets. I'm sorry to say that commercial anodizers don't share secrets much. You also need to realize that we are all (for the most part) home/hobby anodizers. We really don't know the answers to your questions.
I do things. |
Sulfuric concentration should be 15%/wt = 22.0 av oz/gal = 12 fluid ounces/gallon = 9.3%/volume = 165.3 grams/liter. Hardcoat or Softcoat both concentrations are the same.
If you are going for a jet black you gotta go with type II anodizing. From my notes if you want black for 2024 or 6061 you need a thickness of over 3 mils. thats doing it type III hard coat at 32F. 24-36 amps per sq ft. I don't have any experience with Hardcoat just what I've read. |
| Anodizing with a rectifier | sgunn911 | Anodizing Questions | 1 | 06-24-2004 07:28 PM |
| Color depth vs. anodizing time | NeoMoses | Anodizing Questions | 17 | 02-03-2004 10:06 PM |
| Complicated things for a total anodizing newbie. | taylorm | Anodizing Questions | 2 | 01-19-2004 11:50 AM |
| Anodizing different alloys | TONYZ | Anodizing Questions | 2 | 11-02-2003 02:31 PM |
| Titanium anodizing | lorenzo | Other Metal Finishing Questions | 1 | 06-27-2003 09:56 AM |
